User functions
User functions - Help needed for simple problem - Сообщения
#1 Опубликовано: 25.04.2019 04:35:25
AndreasH
AndreasH
test.sm (7,4 КиБ) скачан 1180 раз(а).
Dear all. I am trying to solve an equation, eq. See attached .sm file. The equation does not have the variable directly, but via other definitions. I can't make this work. Anyone out there able to help quickly?
-Andreas-
#2 Опубликовано: 25.04.2019 06:28:57
Hello Andreas,
there are several issues in your worksheet.
  • The shear stress must be Tau(F) or Tau - at your choice - both in definition and in Von Mises equation;
  • Once you fix it you can see that units of Tau are wrong, it's a force while should be a stress - F/(b*L) I guess;
  • Then you should handle the unit of F; use eq(F) to define the Von Mises yeld criterion and set the unit in the first argument of solve, like eq(F*'kN) or eq(F*'N);
  • Finally give a range to solve, otherwise the default of the program you are running it is used;
test - r1.sm (11,99 КиБ) скачан 1158 раз(а).
sergio 25.04.2019 06:41:00
#3 Опубликовано: 25.04.2019 08:23:38
AndreasH
AndreasH
Thank you Davide.
Sloppy mistake on my part on the shear stress definition Tau. By the way, can the solve-function return with a unit number or does it have to return a unitless answer?
I can easily fix it of course by writing F:=solve(eq(F*'kN),F,0,1000)*'kN
-Andreas-
#4 Опубликовано: 25.04.2019 09:03:45
Thank you Davide.
-Andreas-
Yes I forget it, that's the way to set the output units (solve as for now can't handle automatically input/output units of unknowns).
