Stable: SMath Studio 0.99.6839 (22 September 2018) - Сообщения
Список изменений (между версиями 0.99.6823 и 0.99.6839)
Исправления
- Matrix transpose fixed for nested matrices;
- SS-3535: Installation of the plug-in which was previously removed fixed;
- Functionality to delete plug-in which was just installed (without program restarting) fixed;
- Greek symbols not shown on tools palette on Linux fixed.
Разное
- Interface translations updated;
- Refactoring.
Скачать
SMathStudioDesktop.0_99_6839.Mono.tar.gz (1,33 МиБ) скачан 4339 раз(а).
SMathStudioDesktop.0_99_6839.Setup.msi (2,2 МиБ) скачан 23392 раз(а).
- Desktop (Windows):
Framework: .NET Framework 2.0 or higher - Desktop (Linux):
- [ARA] Arabic / العربي
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
WroteIn this version I get following error for the Excel plugin
In the repository I've already updated the code some days ago; if the plugin linked in my post works for you we can release the plugin (I can't test it directly in these days).
WroteWroteIn this version I get following error for the Excel plugin
This worked well, thank you
EDIT: It's IE Smart Screen filter that's causing the issue
WroteAre the plugin's and documentation supposed to be in the same file structure as the program? I updated my computer SMath program, plugins, and the core handbook. I then updated my portable drive version of SMath and all of the plugins and handbooks are showing up as updated. I had not updated my portable version in months. I find it strange that the portable version is possibly reading the installed versions plugins, PDFs, etc.
Have you set the portable.version file? Otherwise the extensions referenced are those in the %APPDATA%/SMath path
WroteFunny. The portable.version file was indeed missing in my portable file folder! I'll keep a closer eye on it as corporate antivirus may have deleted it and I did not notice it.
Hi ElSid. Maybe that is because the file portable.version have length 0. With some aggressive settings the antivirus delete those files.
Wrote[q
What is the status on this? I had the same problem with the plugin last month and rolled back to the previous version.
The plugin was updated at the begin of the month, it is published as beta.
![2018-09-23 19_14_11-SMath Studio - [Page1].png](/ru-RU/files/Download/C6gTkg/2018-09-23-19_14_11-SMath-Studio---[Page1].png)
