Units in a Matrix
Units in a Matrix - Want to Change Units - Сообщения
#1 Опубликовано: 10.07.2018 20:32:24
Dik
Dik
It's great that matrices can have different units for their column values.
Is it possible to change the default values for the various columns? For example, from kg.m^2/sec^2 to kN.m and from kg.m/sec^2 to kN?
I've tried using the default inverse to eliminate the unit, and, then multiplying the unitless value by the unit I'd like to change it to. The result is the default unit.
Dik
