SMath Documentation Portal
SMath Documentation Portal - The central hub for SMath knowledge - Сообщения
#1 Опубликовано: 26.10.2026 11:37:17
SMath Israel
SMath Israel
4 сообщений из 2 724 понравились пользователям.
Группа: Administrator
We've rethought how you access our knowledge base and are pleased to introduce the new SMath documentation portal: https://docs.smath.com/
It is designed to replace scattered, hard-to-maintain resources with a single, reliable source of information about SMath products.
What's new:
  • The content has been updated and expanded.
  • Language support has been extended to make the documentation easier to use in regions where SMath is popular: it is now available in English, Russian, German, Spanish, Portuguese, and Chinese.
  • And, of course, we haven't forgotten the dark theme you've asked for so often.
  • Something we're especially proud of: the new search. It works exactly the way we always wanted, searching strictly within the language you've selected, so articles in other languages won't show up in your results.
We invite you to explore the portal and share your feedback. If you spot a mistake, please let us know at support@smath.com.
