Drop-down list
Drop-down list - Сообщения
#1 Опубликовано: 05.06.2013 03:02:03
jirijirkas
jirijirkas
I want to aks if I can make somethink like drop-down list. I want to read data (sectional characteristics) from table (matrix) according to name of the profile (e.g.: IPE 100). I have table and I read data (via vlookup(value,table,column)), but I have to write exact title as a parametr, I want something like drop-down list where can I choose profil from list.
Drop-down list
#2 Опубликовано: 05.06.2013 03:15:42
It's already available; if you are using the latest Nightly build, go to the online gallery and download the Combobox Region plugin.
After the download a new item will appear in the Insert menu.
There is not a drop-down list, but you can choose the option by a left-click of the mouse. Input matrix must be selected with the context menu item (right-click over the the object, values > name_of_an_existing_matrix); in the placeholder the output variable.
Here some screenshots.
regards,
w3b5urf3r
ioan92 05.06.2013 05:21:00
#3 Опубликовано: 05.06.2013 04:03:11
jirijirkas
jirijirkas
Thanks, it works, but it is possible to modify this plugin to make drop-down list? Because if I have a really long list is a little uncomfortable to click through the whole list.
#4 Опубликовано: 05.06.2013 04:13:01
I don't know, I think yes, but this is a question for the developper... As you can see is not embedded with the program, I suppose because is not yet completed.
regards,
w3b5urf3r
