Program to create TOC based on files in directory
Program to create TOC based on files in directory - Small program - Сообщения
#1 Опубликовано: 16.04.2018 19:43:22
m227
m227
4 сообщений из 29 понравились и 1 не понравились пользователям.
Hi, I just needed to make a table of contents file built from hyperlinks. I installed Hyperlink Region of Davide Carpi but found creating hyperlinks to be too uncomfortable for many files. So I wrote small (Windows) program to facilitate this functionality. Tested on Win7/64, Win10. I'm not sure if i did not do something already done. Screenshots and exe file attached.
SMath_Helpers.7z (39,37 КиБ) скачан 871 раз(а).
Andrey Ivashov 17.04.2018 17:38:00, sergio 17.04.2018 05:09:00, Davide Carpi 17.04.2018 02:58:00
#2 Опубликовано: 16.04.2018 23:59:41
gabben
gabben
1 сообщений из 7 понравились пользователям.
I have found myself in the same situation. This tool is a great help. Thank you.
#3 Опубликовано: 17.04.2018 00:41:57
A TOC for some simple/nvariant models Mathcad style might help.
But in real Smath, you will accumulate work by categories that
you constantly update. Click on your Smath file Directory,
browse much quicker than browsing 100's pages TOC.
In few scroll, I find fast among 1500 Smath work sheets.
#4 Опубликовано: 17.04.2018 02:29:44
gabben
gabben
Great that youve found a way that works for you. Please be careful with coining whats "real" Smath and whats not - the method you describe does not fit all use cases.
#5 Опубликовано: 17.04.2018 05:15:53
m227
m227
Jean, gabben is right. My sample case was different: I prepared about 30 sample files for students. I simply wanted to make list of samples in the same format as they are (i had to have it also as PDF file). I am aware that this is not a browser replacement. If it matters I can prepare plug-in some time (if i grab more python or c#), I think it could be trivial for Davide. Here is upgraded version.
SMath_Helpers.7z (41,29 КиБ) скачан 891 раз(а).
#6 Опубликовано: 17.04.2018 07:24:22
Nice tool
There is the text region utilities (but works on text region hyperlinks, thus *.sm and *.smz files only)
Can I add your utility in the wiki?
BTW, document sections+TOC plugin still work in progress, need some further improvement in Writer Region...
frapuano 17.04.2018 08:45:00, sergio 17.04.2018 07:46:00, Andrey Ivashov 17.04.2018 17:38:00
#7 Опубликовано: 17.04.2018 10:27:09
m227
m227
Davide, thank you for your praise, feel free to add this tool, I am glad if I could help someone. It can be my small contribution to SMath development. By the way I did some other tools, i.e. copying excel ranges as tables to SMath Studio and recently (not finished yet) translating SMath equations to MS Word 2007+ equations (to use them in internal Word Equation form instead of raster pictures). I am sure that if I used Python I could make internal plug-ins, but as my native environment is Delphi I am a little limited. Fortunately (Long live Andrey!) SMath XML and clipboard format is very self-explaining.
#8 Опубликовано: 17.04.2018 10:58:48
A TOC for some simple/invariant models Mathcad style might help.
... Mathcad 8 Pro. TOC of MathSoft models 977 work sheets [65 MB]
Personally, I expanded all sections in a single "visit sheet".
Easy to glance by section and title ... click, bingo !
Finding something of interest is fast/magic.
My Smath work sheet Directory is in C:\Smath 6179 [1408 documents, 117 MB]
All that stuff is by categories,
as easy to glance than Mathcad TOC and personal *.mcd
#9 Опубликовано: 17.04.2018 11:05:42
... all my Instrumentation Category 89 documents, 10 MB
... all in suite, easy to retrieve from titles.
#10 Опубликовано: 17.04.2018 17:46:56
m227
m227
Jean, I am amazed by your huge collection of MathCad files and gathered knowledge. Such library surely must have some sort of order to be usable. However boasting of space used to store this data does not move me at all. After working with a big hog as MathCad is I was astonished by SMath Studio tiny size. When I downloaded SMath Studio for the first time I could not believe that it could be such small. This is what I call Zen of programming. Of course today computers have plenty of storage so no need to worry about files size. Anyway, imho the size is not any indicator of quality (and sometimes it is in a negative sense).
#11 Опубликовано: 17.04.2018 18:15:16
Thank you
About translating to Word equations you can found the same feature in DataExchange (when you save ODT files, they can be opened both in LibreOffice and in Word with editable math) and even in WriterRegion (single equation can be copied and pasted in MS Word); about cells conversion there are the clipboard region and the utility linked above (sources of all are in our repository and are in C#, no soures for the external tool)
I know thesse are different approaches than your that is based on the xml file, but might be a point of contact to start learning about how plugins are made
True
#12 Опубликовано: 17.04.2018 18:21:52
Yes, Mathcad 8 Pro. TOC model sheets are ordered by categories,
per say ODE solvers. This TOC was removed in MCD 11, replaced
by another TOC muchmuch less educative and smaller.
OriginLab, very powerful is only 6 MB ~ 3 times Smath.
Mathcad was [still is] a collection of subcontracts,
some of them very immense ! Mathcad 3D !
