Programming Regions in a SMath Document (Possible?)
Programming Regions in a SMath Document (Possible?) - Is it possible to control objects in SMath (location, value, etc.)? - Сообщения
#1 Опубликовано: 15.09.2015 18:32:29
9_82abZ2
9_82abZ2
0 сообщений из 7 понравились пользователям.
Greetings,
I am interested in forcing an 'image' to the top right hand corner of the sheet/document. Also, when a new page break is entered, I would like this image to be generated in the same location as the previous page.
I would like to supplement the existing header/footer with a company logo and would like all of the users in my company to create documents w/o having to worry about setting up the header/footer and copying and pasting images. I thought I would achieve this with the scripting region, but this plugin appears to only allow a user to access the 'Smath.Math' namespace.
In short, i was wondering if there exists a feature similar to MS Office's 'visual basic editor' where you can control what is on the sheet.
Thank you,
