[SS-2300] Greater than Or Equal To
[SS-2300] Greater than Or Equal To - If statement returns wrong value - Сообщения
#1 Опубликовано: 04.01.2017 14:00:05
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
It seems odd that I am finding this problem now. Maybe it is a recent bug. Or maybe I am doing something wrong?
Both statements should return b:=1 but when I add the unit of feet. There is a problem.
Any thoughts?
Thanks!Greater than or Equal to.sm (3,7 КиБ) скачан 1297 раз(а).
#2 Опубликовано: 04.01.2017 14:29:09
It seems that it is a rounding problem in internal transformation of SMath from ft to m.
In fact, with x = 3.0001 ft the problem does not exist.
#3 Опубликовано: 04.01.2017 15:23:34
it is SS-2300
#4 Опубликовано: 04.01.2017 16:54:00
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
A workaround to that issue would be to divide by the units. It does not look elegant, but it is functional.
#5 Опубликовано: 04.01.2017 18:38:18
Ryan Freund
Ryan Freund
I'm not sure how I haven't noticed this before. Anyway, thanks!
Another Work Around:
Greater than or Equal to_2.sm (5,28 КиБ) скачан 1319 раз(а).
What is the best way to post embedded photos on this site? Typically I use onedrive for storage (fyi).
#6 Опубликовано: 04.01.2017 20:19:46
Simply add an attachment, like for *.sm/*.smz files.
#7 Опубликовано: 05.01.2017 09:25:13
1. You must be in the "Post reply" mode
2. Where you leave the cursor: click on the clip
"Insert an existing attachment or upload a new file"
look for it in your PC, double click, click "Post".
If you have multiple attachments at the end of your message,
keep adding. Before posting final, put the cursor after the
first attachment, press "Enter".it will pile down ...
keep doing that up until they are all piled down...Post final.
All that works for "images" Bug.gif and work sheets *.sm
Davide Carpi 05.01.2017 15:53:00
