[LINUX] "Attempted to divide by zero" when saving file
[LINUX] "Attempted to divide by zero" when saving file - Smath crashes when I try to save a file - Сообщения
#1 Опубликовано: 07.12.2015 16:37:41
Florian
Florian
Hey all,
I have a problem with SMath. Since I've updated my system to Ubuntu 15.10 I cannot save files in SMath. Everytime I try to "save" or "save as" I get the message "Attempted to divide by zero." See attached screenshot. Only except when the sheet is complete empty.
I have installed the latest version of mono. Is something more missing?
This is what the terminal gives on startup:
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
- [AppDir] HTML Export (1.13.5737.24525)
- [AppDir] Export to image (1.9.5737.24526)
- [AppDir] Picture Region (1.10.5737.24525)
- [AppDir] Plot Region (1.9.5737.24527)
- [AppDir] SMath Studio Files Plugin (1.9.5737.24527)
- [AppDir] Special Functions (1.11.5737.24524)
- [AppDir] Text Region (1.10.5737.24526)
- [AppDir] SMath Viewer Files Plugin (1.1.5737.24528)
- [AppDir] XMCD Files Plugin (1.12.5737.24526)
What does the warning mean?
Best regards,
Florian
