Trouble with col(1,matrix)
Trouble with col(1,matrix) - Mathcad Experience is killing the very old guy - Сообщения
#1 Опубликовано: 24.02.2019 22:00:11
RegCurry
RegCurry
0 сообщений из 57 понравились пользователям.
Please help with the col(1,matrix) function in the attached Smath file.
Thanks as always,
Reg
POINTS PER DECADE.sm (14,64 КиБ) скачан 1188 раз(а).
#2 Опубликовано: 24.02.2019 22:12:09
RegCurry
RegCurry
Sorry. I apparently can't read either. Should be col(FF,1)
#3 Опубликовано: 25.02.2019 00:31:08
Just the opposite col(matrix,col#)
POINTS PER DECADE.sm (18,21 КиБ) скачан 1210 раз(а).
#4 Опубликовано: 25.02.2019 00:54:50
I apparently can't read either.Should be col(FF,1
In the returned document: set 15 decimals
The M matrix construction/display is all OK
BTW, OK means "0 Killed" marked in the War log book
