Graphing a function, but I cannot adjust the axes limits
Graphing a function, but I cannot adjust the axes limits - Title. - Сообщения
#1 Опубликовано: 01.08.2024 11:49:35
ALLAN PAOLO LABARTINOS ALMAJOSE
I am completely aware that the documentation said that you cannot adjust the axes limits when using vanilla plot function. Is there a plugin that is able to resolve this issue?
Or rephrasing; is there an available plugin that allows users to plot functions and adjust the axes limits of the plot?
TYIA.
#2 Опубликовано: 01.08.2024 18:38:01
You can use XYPlot and setprop() function for that purpose.
Here is sample file for setprop function.
setprop.sm (21,36 КиБ) скачан 1650 раз(а).
ioan92 02.08.2024 14:33:00
#3 Опубликовано: 07.08.2024 22:03:13
⚜ Kenny Lemens, P.E. ᵂᴵ
85 сообщений из 181 понравились пользователям.
Greetings,
As a note: the 'name' of the graph (in this case XYPlot1 and XYPlot2) is specified via the XY-Plot Properties (i.e., double-click the graph to see the full list of properties); one of those fields is called "Name" which would be the title to reference the Plot through the 'setprop()' command.
May this be of Good Help;
