1. This type of spline is for high Technical/Scientific works.
2. It roams around points, governed by the vector of knots.
3. Not easy to manipulate: trial/error for best fit.
4. Most likely it will crash Smath ... save a working copy.
5. Supports indirectly integration [via Smath ainterp typical].
6. Supports infinitesimal derivative ...
at this point: you may adjust the vector of knots from
visual inspection of the derivative.
Spline0 Quadratic Lagrange Knots.sm (38,28 КиБ) скачан 1264 раз(а).
