FUNCTION MATRIX ADR SHEET
FUNCTION MATRIX ADR SHEET - Need help manipulating the matrix - Сообщения
#1 Опубликовано: 09.01.2021 19:19:46
Ruben Sidranski
Ruben Sidranski
Some direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix.ADR.sm (127,5 КиБ) скачан 1080 раз(а).
Thank you
#2 Опубликовано: 09.01.2021 22:34:24
Quick brute force for a range of values, AFAIU.
Cheers old Collab Elsid ... Jean
ADR brute force.sm (150,39 КиБ) скачан 1104 раз(а).
#3 Опубликовано: 10.01.2021 01:02:58
... here is a more complete search.
ADR brute force augmented.sm (159,59 КиБ) скачан 1066 раз(а).
#4 Опубликовано: 10.01.2021 21:17:49
Don't miss the Truth Table Companion in Samples.
#5 Опубликовано: 10.01.2021 23:16:00
Aaah now I get what you meant.
This should solve your problem.
Deleted previous post.
#6 Опубликовано: 11.01.2021 12:56:03
Ruben Sidranski
Ruben Sidranski
Is this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
#7 Опубликовано: 11.01.2021 13:25:58
InterpBilinear() is in the 'Custom Functions' plugin.
Basically an interpolation with two variable.
Good and useful function.
#8 Опубликовано: 11.01.2021 14:09:54
... from the attached example,
get inspired to construct the data ready for matrix interpolation.
Elsid Spline Table.sm (19,1 КиБ) скачан 1088 раз(а).
