Function call does not evaluate numerically inside a for() loop
Function call does not evaluate numerically inside a for() loop - Сообщения
#21 Опубликовано: 24.04.2018 18:52:06
Alexander O. Melnik
Alexander O. Melnik
Hi Jean,
I get an error running your worksheet at variable "User".
I also managed to come up with stable solver for both neutral axis depth "na" and neutral axis rotation angle "alpha". Problem is it can take up to 20 seconds per single solution and i potentially need to run it ~50 times. Any pointers on speeding up function calls?
Thanks!
formulaR8.sm (282,02 КиБ) скачан 1280 раз(а).
#22 Опубликовано: 24.04.2018 23:53:04
Hi Jean,
Thanks!
I lost track of the project as finally the bilinear interpolation solves for both mutually.
Pretty easy to construct the data table wrt "na" & "alpha". Try yourself, if not sure,
please give me the respective ranges. The bilinear data table needs not be square.
It can be rectangular horizontal/vertical.
Cheers Alex ... Jean
Project_0 Biaxial Bilinear [jmG] Copy.sm (115,32 КиБ) скачан 1121 раз(а).
#23 Опубликовано: 25.04.2018 00:21:52
... an otherwise bi-linear demo.
Bi-linear linterp interpolation has the virtue of quadratic.
QuadraticSplineCreateMesh.sm (15,59 КиБ) скачан 1308 раз(а).
