Error - result is above maximum allowed positive number
Error - result is above maximum allowed positive number - Сообщения
#1 Опубликовано: 05.05.2021 20:58:55
dimart17@mainl.ru
dimart17@mainl.ru
Hi guys (and girls of course if any)
can someone help me with the following error message and what is wrong here:
Thanks!
#2 Опубликовано: 05.05.2021 21:29:38
churichuro
churichuro
29 сообщений из 79 понравились пользователям.
this does the trick!
Bruno Choquepata 06.05.2021 00:38:00
#3 Опубликовано: 06.05.2021 00:43:30
Bruno Choquepata
Bruno Choquepata
Could you help me to make this graph please?,
thanks
ARMONICA.sm (17,05 КиБ) скачан 1129 раз(а).
#4 Опубликовано: 06.05.2021 02:01:46
Fridel Selitsky
Fridel Selitsky
Graph
ARMONICA1.sm (18,14 КиБ) скачан 1120 раз(а).
Bruno Choquepata 06.05.2021 02:23:00
#5 Опубликовано: 06.05.2021 04:35:06
However, to have a correct representation you must use a smaller time step. The period is equal to 0.04 sec -> use at least 0.001 sec
#6 Опубликовано: 06.05.2021 14:08:37
dimart17@mainl.ru
dimart17@mainl.ru
Thanks a lot mate! This really does the trick!
#7 Опубликовано: 06.05.2021 14:53:36
Your document does not open incorrect format
This bug is inferno, maybe caused by your AV.
It has never been addressed from many complains.
#8 Опубликовано: 06.05.2021 19:47:25
dimart17@mainl.ru
dimart17@mainl.ru
Now I need to multiply two arrays of values and get a third array of values. This is very easy. For some reason I get just one figure instead of array. What is wrong here and how to solve this?
#9 Опубликовано: 06.05.2021 20:12:39
#10 Опубликовано: 06.05.2021 20:17:44
dimart17@mainl.ru
dimart17@mainl.ru
Thanks a lot, buddy! Much appreciated! This program is really good but needs some good help section for beginners like myself
#11 Опубликовано: 06.05.2021 20:28:20
There are different methods you can use.
You either multiply with vectorize function. Sometimes this function will not avail.
Or multiply the elements piece by piece with for loop, in some cases this is the only way.
Or calculate dyadic product and take the transverse results of it. Why? because you can (swh).
