"Unit don't match"
"Unit don't match" - If I insert a unit SMath shows "Unit don't match" - Сообщения
#1 Опубликовано: 10.04.2019 03:54:52
MR
MR
I'm new to SMath. It's a great software but I'm frustrated with an (maybe simple) error.
I try to calculate a density wich follows a simple linear equation:
The equation is: D = 0,0006x+1
x stands for the mass.
Now I try to calculate the density with different masses:
How you see I can't solve the second equation with the unit "g". SMath shows "Unit don't match". I try different ways to insert units but it doesn't work in any direction.
So, what can I do? Where is the failure?
Thanks in advance for your help!
#2 Опубликовано: 10.04.2019 05:15:04
The formulation you wrote for the density calculation (linear equation) would suggest a dimensionless formulation (those typical equations contained in technical manuals or codes). Therefore it must be used in dimensionless form with the quantities inserted without a unit of measurement. With m2 you have instead used a unit of measurement that caused the error by not being able to add up a dimensionless quantity (1) with a quantity with unit of measure (g)
#3 Опубликовано: 10.04.2019 05:24:13
MR
MR
Thank you for quick reply!
I will calculate it dimensionless.
#4 Опубликовано: 10.04.2019 05:32:30
The 2 typical approaches; as said by Sergio the dimensionless operand drives the result:
https://en.smath.com/cloud/worksheet/3ecekeDo
#5 Опубликовано: 10.04.2019 10:57:16
So, what can I do?
... work Engineering/Scientific projects Unitless
Maths are unitless, so projects using maths.
IMHO, the attached is a good example.
Inst_Colebrook Pipe Data.sm (59,42 КиБ) скачан 1259 раз(а).
#6 Опубликовано: 11.04.2019 02:49:20
MR
MR
Thanks for all answers!
#7 Опубликовано: 11.04.2019 09:47:40
Knowing in what units the document is designed/produced,
you can always append the unit in the result ... like this:
you can't define kg/m³:=1
otherwise kg_m³:=1
This SS 6179 should work in your latest SS version.
Inst_Type J Genfit Rational J_8.sm (96,66 КиБ) скачан 1229 раз(а).
