Solve for Unknowns
Solve for Unknowns - 9 Equations, 9 Unknowns - Сообщения
#1 Опубликовано: 16.01.2018 16:57:54
Norm Schutzkus
Norm Schutzkus
9 сообщений из 90 понравились пользователям.
Transferring a MC sheet. How can I solve for the unknowns?BJT Circuit Analysis.sm (54,64 КиБ) скачан 1281 раз(а).
#2 Опубликовано: 16.01.2018 17:48:31
Arie
Arie
For using Linsolve(1) function, you need to put the system of equations into a matrix. The result computes the unknowns in alphabetical order, I believe. You can retrieve this information using Unknowns function.
BJT Circuit Analysis.sm (63,79 КиБ) скачан 1326 раз(а).
#3 Опубликовано: 16.01.2018 18:45:55
Norm Schutzkus
Norm Schutzkus
Many thanks!
#4 Опубликовано: 16.01.2018 22:15:48
Unknowns("variable") - ... from f(x) menu
Returns a vector of unassigned variables contained in "1:variable".
If unknowns are not found, returns 0.
Solutions are returned in lexicographic order ... inspect Unknowns(A)
#5 Опубликовано: 16.01.2018 23:41:57
... thanks for this LinSolve application.
Maths LinSolve.sm (69,68 КиБ) скачан 1331 раз(а).
#6 Опубликовано: 17.01.2018 04:03:40
Here is another MCD sheet, converted Smath [circuit application].
Iterative solvers are common in Engineering.
Solve TREASURY_1 [Iterate L, Lc].sm (58,21 КиБ) скачан 1171 раз(а).
#7 Опубликовано: 17.01.2018 10:33:57
Norm Schutzkus
Norm Schutzkus
Thanks Jean, for the Solve Treasury worksheet. I updated my sheet splitting the ampere and voltage values apart.
Best regards,
NormBJT Circuit Analysis.sm (49,34 КиБ) скачан 1262 раз(а).
#8 Опубликовано: 17.01.2018 11:07:30
Arie
Arie
I've modified the LinSolve(1) function and created a LinSolve2(2) function that allows user to specify result order vector. I've named it LinSolve2 to avoid confusion with the LinSolve(2) Maxima Plugin function.
Not sure if this is useful for anyone.
BJT Circuit Analysis (1).sm (86,73 КиБ) скачан 1317 раз(а).
#9 Опубликовано: 18.01.2018 01:23:34
Lovely separation of result.
A useful companion attached, more examples in future.
Solve LinSolve COMPANION.sm (31,58 КиБ) скачан 1301 раз(а).
#10 Опубликовано: 18.01.2018 09:35:41
Arie
Arie
Jean, I believe the original LinSolve function is a snippet created by Martin (mkraska). You can find it within the Snippet Manager in SMath.
#11 Опубликовано: 19.01.2018 12:07:33
I think so ... those gyzmas # are Martin style.
Easy to removed all # ... like this
1. start by the LHS in the program definition
2. put the cursor on the right of the #
3. press F8 to see all selected, in the program core as well
4. once selected, press Backspace ... gone
5. next proceed in the core of the program
6. result => nice and clean
Cheers
