Plot - axis scale
Plot - axis scale - Сообщения
#1 Опубликовано: 30.11.2014 12:05:42
Kamil
Kamil
I can't change the axis scale, using wheel or touchpad. When I move up or down, numbers on an axis grows. I can't "zoom out". Is the any other way to change the scale? Using keyboard for example
#2 Опубликовано: 02.12.2014 06:14:48
Use SHIFT+mouseWheel or CTRL+mouseWheel to change the scale of a single axis (x and y, respectively).
If you want a precise scaling, use a plugin (like X-Y Plot Region)
Or you have experienced a bug?
