6179 Crashes Legendre
6179 Crashes Legendre - 6179 Crashes Legendre - Сообщения
#1 Опубликовано: 03.01.2017 12:52:58
This one is not nice ! It may reflect on other of this kind
[Hermite ...] from the documentation. 5346 was OK .
Autocalc is OFF.
Bug 6179 Integrate Legendre Crashes.sm (11,36 КиБ) скачан 1363 раз(а).
Davide Carpi 03.01.2017 13:11:00, Andrey Ivashov 07.01.2017 18:56:00
#2 Опубликовано: 03.01.2017 13:11:27
confirmed, thank you!
#3 Опубликовано: 08.01.2017 10:00:55
... Ah ! this damned bug is isolated, but no cure.
Was OK 5346 ! Now dead 6179.
Bug 6179 Integrate Legendre Crashes.sm (39,09 КиБ) скачан 1340 раз(а).
Radovan Omorjan 08.01.2017 12:05:00
#4 Опубликовано: 08.01.2017 12:05:59
Confirmed,
Ra
#5 Опубликовано: 13.01.2017 13:26:26
Was OK 5346 but not 6179.
At least it is isolated.
Bug 6179 Legendre Crashes.sm (39,22 КиБ) скачан 1354 раз(а).
#6 Опубликовано: 13.01.2017 14:01:29
Hello Jean,
Seems the crash it is related with the name of the iterator argument of sum().
Until is not fixed you can cure it by renaming k in either one of L(x,n) or the for loop (move on the variable k, press F8 and rename it at once), then you can evaluate safely.
moderation: topics merged
#7 Опубликовано: 14.01.2017 12:55:38
Hello Jean,
Thanks Davide: it evaluates.
But the nice symbolic evaluation can't be assigned as expanded.
So, for the coefficients and polyroots we are forced to copy/paste.
Not convenient for n > 4
Up until now: Smath 6179 does not accept Legendre as companion.
This "bug" of impossible isolation reflects on the "numden".
Was working great 5346 but not anymore 6179. I understand why
the collab from Russia asked several times about "numden".
My nice western 5346 turned red over east !!!
Legendre plots for any 'n'. For the roots and weigth: from the web.
Bug 6179 Legendre for Doctoring.sm (49,72 КиБ) скачан 1330 раз(а).
