anyway to custom function description?
anyway to custom function description? - Сообщения
#1 Опубликовано: 22.05.2024 10:00:03
zhkz
zhkz
3 сообщений из 14 понравились пользователям.
hi,everyone
during study Smath Studio , I would like to add some my own description to functions just for better memory / understanding .
so is there anyway to do that?
i have tried for example :
but failed .
so here to put this question ,
besides , is it possible to support orther languages?
thanks for your suggestion/comments.
thanks!
#2 Опубликовано: 22.05.2024 14:43:18
1 440 сообщений из 2 929 понравились пользователям.
You can add your own description(s) in this way.
If you mean in the description, just right click on the region that holds the definition and change the language on the context menu; you can add a description for each language.
If you want another language to be supported, you have to ask Andrey directly.
sergio 22.05.2024 16:19:00, Thiago Pereira 26.06.2024 00:05:00
#3 Опубликовано: 22.05.2024 19:08:39
zhkz
zhkz
hi,Davide, thanks very much, this method works, but it didn't fully achieve my goal.
what i want is add some note about that function in Function-Description ,
Snipaste_2024-05-22_20-01-34.jpg,
and in the Example field , it didn't give a truly example but a syntax to call that function ,
so i wonder if there a way to add my own description about that function .
thanks.
#4 Опубликовано: 22.05.2024 20:57:29
AFAIK that's not possible. The dialog loads the descriptions stored in the plugins at program startup. Currently the only way would be to recompile the plugin with your own descriptions edited in the source code.
zhkz 23.05.2024 22:23:00
#5 Опубликовано: 23.05.2024 22:23:42
zhkz
zhkz
that seems hard for me..
thanks suggestion!
