Add a Force Density, or Unit Weight, Dimension
Add a Force Density, or Unit Weight, Dimension - Сообщения
#1 Опубликовано: 25.04.2014 14:50:23
Ricyteach
Ricyteach
2 сообщений из 14 понравились пользователям.
I am attempting to add my own custom unit of pound force per cubic foot (pcf) to the Units.xml file; however, there does not appear to be a dimension available for Force Density (sometimes referred to as "Unit Weight" ) .
Adding this line to Units.xml results in an error:
Is there a way I can accomplish this on my own or does the source code need to be modified...?
Thanks.
#2 Опубликовано: 29.04.2014 16:02:53
2 343 сообщений из 4 044 понравились пользователям.
Группа: Super Administrator
Hello. Next version of SMath Studio will allow to set your own dimension XML file. Currently it is not possible.
Davide Carpi 29.04.2014 17:14:00
#3 Опубликовано: 07.05.2014 09:40:43
Ricyteach
Ricyteach
This is great news! Thank you for the update!
#4 Опубликовано: 25.09.2014 08:09:09
Ricyteach
Ricyteach
Andrey, did this feature make it into the latest version as planned? If so, what does a user-defined xml dimension file look like? What are the rules for creating one so I can add units for force-density, for example?
#5 Опубликовано: 25.09.2014 11:43:53
Have a look at the file ufhb.xml in the entries directory of the portable distribution. The added dimensions are documented in the interactive handbook [?]> Units of measurement> New units in the inofficial SMath distribution.
Some of these units are language-sensitive.
As the required force density just would add units to the pressure dimension, this should be straightforward.
#6 Опубликовано: 25.09.2014 12:03:23
Ricyteach
Ricyteach
Thanks! I'll have a look at both of those.
Maybe I misunderstand, but force density isn't just adding units to the pressure dimension, is it? Since pressure is FORCE/LENGTH^2 and force density is FORCE/LENGTH^3. Smath didn't have the ability to add user defined units for FORCE/LENGTH^3 before. You are saying that after looking at the above references I should be able to add them now?
#7 Опубликовано: 25.09.2014 13:09:05
Sorry, I just didn't read the previous posts carefully and assumed you were asking for force/area. I added "quantity" units, but to be honest, I forgot, why I used dimension="613". Mostly just try and error. Thus, for force/volume I am not that confident.
#8 Опубликовано: 25.09.2014 13:27:00
Ricyteach
Ricyteach
When I get time I'll give it a try using 613. Hopefully Andrey will be able to let us know if he ended up including this capability in the latest release (it isn't listed in the update log at the forum download thread).
