Custom Units creating
Custom Units creating - Сообщения
#1 Опубликовано: 15.04.2010 22:49:31
2 344 сообщений из 4 057 понравились пользователям.
Группа: Super Administrator
This is possible to create Custom Units for your calculations (SMath Studio 0.88 or higher version). Please, take a look to the picture below for details:
(download sample)
#2 Опубликовано: 11.04.2011 02:35:06
crodgers
crodgers
1 сообщений из 1 понравились пользователям.
Any hints on how to go about setting up a sutom unit dBm decibel with respect to milliwatt
x dBm = 10^(x/10)mW
zapzapouch 02.11.2018 17:19:00
#3 Опубликовано: 11.04.2011 06:40:04
x dBm = 10^(x/10)mW
Here is a possible solution to your problem. Translating between dBm and mW. There is no simple relation between these units like Unit1=k*Unit2 (k = constant) and we have to use functions in this case.
Given functions are defined as 'dBm(.. and 'mW(... in order to see them as units (in blue color).
#4 Опубликовано: 14.07.2014 12:01:46
zapzapouch
zapzapouch
0 сообщений из 27 понравились пользователям.
x dBm = 10^(x/10)mW
Can this be defined so that dBm(2 mW) = 3.01, and mW(3 dBm) = 2 mW, with units inside both function calls?
#5 Опубликовано: 12.09.2014 16:02:39
ziopaper
ziopaper
1 сообщений из 13 понравились пользователям.
here it is
#6 Опубликовано: 09.12.2014 13:18:50
zapzapouch
zapzapouch
Has this situation changed now that there are nonlinear units? http://en.smath.info/forum/default.aspx?g=posts&m=13396#post13396
I'd also like to use dBV, dBu, dBm, etc. in the natural way
#7 Опубликовано: 01.10.2018 13:31:42
zapzapouch
zapzapouch
Any update on this?
