Load different background in the viewer printout
Load different background in the viewer printout - Сообщения
#1 Опубликовано: 15.11.2013 05:43:26
marcofk
marcofk
8 сообщений из 19 понравились пользователям.
Hello all,
I thought a useful addition to the viewer files would be the possibility to add a custom background to the resulting calculation sheet printout. I currently use the background as a frame where to put company logo, date, job number, calculation title etc. essentially a standard calculation sheet template. At present, I can insert a blank template and fill it up manually after printing if I use the viewer. Ideally I'd like to be able to either edit it on the fly or generate it with a third party application and load it in the viewer, which would effectively operate as a stand-alone calculation app for that specific type of calculation.
Any thoughts?
Marco
