Rolling the Torus [under construction]
Rolling the Torus [under construction] - Rolling the Torus [under construction] - Сообщения
#1 Опубликовано: 05.06.2017 22:42:12
... it works, but it must be stopped dancing !
I figure some fixed Euler orientation must be applied ?
Torus.sm (24,31 КиБ) скачан 1343 раз(а).
#2 Опубликовано: 06.06.2017 04:54:19
Fridel Selitsky
Fridel Selitsky
Hello Jean Giraud !
The calculation time will be greatly reduced, if the coordinates are represented as functions
x(t),y(t),z(t).
Torus Mod.sm (27,45 КиБ) скачан 1335 раз(а).
Davide Carpi 06.06.2017 07:25:00
#3 Опубликовано: 06.06.2017 10:06:34
Thanks Ber7 for doctoring !
Orientation is acceptable, ~ 3 minutes visit.
Torus.sm (33,61 КиБ) скачан 1327 раз(а).
Torus Rolling.gif ... updated
#4 Опубликовано: 06.06.2017 14:12:13
Fridel Selitsky
Fridel Selitsky
Good work, Jean. I extended the animation to the full cycle.
Jean Giraud.sm (20,27 КиБ) скачан 1365 раз(а).
Davide Carpi 06.06.2017 16:00:00, Andrey Ivashov 07.06.2017 12:05:00
#5 Опубликовано: 22.09.2017 14:41:02
Fridel Selitsky
Fridel Selitsky
Surface represented by lines.
Jean Giraud2.sm (19,82 КиБ) скачан 1328 раз(а).
