Problem with length() command
Problem with length() command - Сообщения
#1 Опубликовано: 28.05.2012 04:34:39
ska109
ska109
Hi, I have a problem using length() commang.
If used on matrix, it works well, but using the length() command on scalar value (which is, I think, matrix of size 1 by 1), it doesn't work well.
length problem
File with this problem: length_problem.sm.
#2 Опубликовано: 28.05.2012 05:01:40
You get the last math region [MATH=eng]lx_1=length(-1)[/MATH]. If yoo would use numerical equal to, there would be an error issued.
And, no - scalar is not a matrix of size 1 by 1.
Rdaovan
#3 Опубликовано: 17.06.2012 07:31:07
ska109
ska109
thank you for your reply. Is trere any other way (instead of using "length()" command) how to find out the number of solutions of the equation?
Thank you for amazing SMath,
kind regards
Jan Skapa
Rdaovan
#4 Опубликовано: 17.06.2012 07:48:35
Could you be more specific, please?
#5 Опубликовано: 17.06.2012 08:46:45
1 440 сообщений из 2 930 понравились пользователям.
I don't see your file therefore I'm not sure, but I think that this snippet can help you:
varManager.zip
EDIT(1): now i can see your file
use it in this way:
[MATH]x_1:ToArray(x_1)[/MATH]
EDIT(2): instead of [MATH]x_1:ToArray(x_1)[/MATH] you can use [MATH]x_1:stack(x_1)[/MATH]
(x_1 can be an array, a scalar or a text)
then you can use:
[MATH]length(x_1)[/MATH]
regards,
w3b5urf3r
