Novell ZENworks Application Virtualization Popup when running Smath
Novell ZENworks Application Virtualization Popup when running Smath - prompts user on how many days are left in trial - Сообщения
#1 Опубликовано: 19.06.2013 09:15:17
lcesero
lcesero
Hi Andrey,
I am getting a Novell ZENworks Application Virtualization Popup when running Smath
version 0.96 (build 4868). It is informing me that there are only 11 days left before the trial expires.
Louis
#2 Опубликовано: 19.06.2013 09:34:35
Confirmed (SMath Studio 0.96.4868 portable)
regards,
Davide
#3 Опубликовано: 19.06.2013 10:25:36
1 353 сообщений из 2 264 понравились пользователям.
I confirm that with 4868.
With 4875 and following builds, there is no such problem.
#4 Опубликовано: 19.06.2013 10:47:43
kilele
kilele
Microsoft has a software for virtualization, App-V.
I don't know if it is free of charge.
http://www.microsoft.com/en-us/windows/enterprise/products-and-technologies/virtualization/app-v.aspx
http://rorymon.com/blog/index.php/category/app-v/
http://www.brianmadden.com/blogs/timmangan/archive/2013/06/07/simpler-faster-and-cheaper.aspx
#5 Опубликовано: 19.06.2013 12:10:07
kilele
kilele
I tried "Cameyo" and "Enigma Virtual Box", without success possibly because I didn't played with configuration parameters. Both are freeware, I'd try the second one since it is a freeware product provided for a company which sells other type of programs.
#6 Опубликовано: 19.06.2013 15:09:15
2 328 сообщений из 4 022 понравились пользователям.
Группа: Super Administrator
Thank you for the info. It seems I have to finish using of Application Virtualization app for creating Portable versions (I just got a confirmation that finally ZENworks doesn't allow me to buy their product).
It was important because it includes .Net Framework 2.0 and allows users to use SMath Studio without requirement to install .Net Framework first.
Starting from Vista .Net Framework 2.0 is already preinstalled in the system, so I believe there is no need to support such kind of SMath Studio Portable anymore. Instead I will create a Portable packege without .Net included.
Regards.
#7 Опубликовано: 19.06.2013 15:30:18
kilele
kilele
Please consider to make a portableapps.com compatible package
#8 Опубликовано: 01.07.2013 08:20:59
Expired
Only to mention it, the same problem appears in the 0.96.4883 portable.
regards
Davide
