Problem with xlsx import
Problem with xlsx import - Why does this syntax not work - Сообщения
#1 Опубликовано: 10.02.2025 10:46:46
RegRetired
RegRetired
8 сообщений из 144 понравились пользователям.
The sm and the xlsx are in the same folder, yet it will not import data from the xlsx spreadsheet.
Here is the sm file
DAYS BETWEEN DATES.sm (2,53 КиБ) скачан 1745 раз(а).
Here is the xlsx file
DAYS BETWEEN DATES.xlsx (9,14 КиБ) скачан 1190 раз(а).
Thanks for any help.
Reg
By the way, I recently updated SMATH and am having problems. I can no longer click on an sm file and have it open in the updated version. I have to open it through the updated version and save it. I have many files, so this is a real disappointment.
Reg CurryLoveland, CO
#2 Опубликовано: 10.02.2025 11:04:13
RegRetired
RegRetired
I found my syntax error.
However, if someone knows how to make the updated SMATH open a file created in the previous version and have SMATH automatically update it, that would really help.
Thansk
#3 Опубликовано: 10.02.2025 18:59:32
You mean that the OS has lost the file association? (blank files which are asked to choose an application to open them?)
#4 Опубликовано: 11.02.2025 03:55:48
RegRetired
RegRetired
No, it opens the file; however, this dialog box appears every time. If I open the file from SMATH and then save it, I no longer get this dialog box.🤷‍♂️
#5 Опубликовано: 11.02.2025 04:28:57
RegRetired
RegRetired
Davide,
It does not work even if I open the file in SMATH and save it. When I click on the file I also get this error box in addition to the above one. I have updated SMATH and that's when the problems started.
Should I uninstall SMATH and try to reinstall. It's been so long I have forgotten how to do that since I don't have the install file. When I select download on the update dialog box above, it does not tell me where the download is. It's not in my normal download location. So, I just installed it.
Anyway, I am very frustrated.
Thanks for your help.
Reg
#6 Опубликовано: 11.02.2025 04:42:58
RegRetired
RegRetired
Davide,
I think I found the problem. Apparently, when I did the update, it created a second installation of SMATH. I removed the older one from control panel and that seems to have fixed the problem...as far as I can tell at this time.
I'm getting too old for all this. But, it keeps me out of the bars at night.
Davide Carpi 11.02.2025 04:55:00
#7 Опубликовано: 11.02.2025 04:59:47
I'm glad you were able to fix it on your own. I don't think I could have figured that scenario myself.
