Limit
Limit - Сообщения
#1 Опубликовано: 10.09.2023 16:44:56
Valery Ochkov
Valery Ochkov
66 сообщений из 696 понравились пользователям.
How to work with limits in SMath?
#2 Опубликовано: 11.09.2023 01:46:20
The Maxima plugin can handle limits symbolically. Below you find a preview of the SMath with Maxima handbook, it is to appear with the next release of the Maxima plugin. Ordinary limits work in the current version. Single sided limits will be part of the next release.
2023-09-11 06_50_04-C__FHB_Software_SMath_SMath Skript_SMath with Maxima.lyx - LyX.png
#3 Опубликовано: 11.09.2023 12:30:01
Valery Ochkov
Valery Ochkov
Thanks!
But I have
Send please the SMath-file
#4 Опубликовано: 11.09.2023 12:34:09
Oscar Campo
Oscar Campo
Thanks!
But I have
Do you have maxima installed?
Valery Ochkov 12.09.2023 10:09:00
#5 Опубликовано: 12.09.2023 08:25:04
Instructions for installation
Install.pdf (155,27 КиБ) скачан 1116 раз(а).
Valery Ochkov 12.09.2023 10:09:00, Oscar Campo 12.09.2023 13:55:00
#6 Опубликовано: 13.09.2023 09:28:19
There is a limit function Razonar provided sometime ago.
It is a native SMath function, so it won't need anything installed.
If it suits, you can use that too.
https://en.smath.com/forum/yaf_postst20355_Limits.aspx
Oscar Campo 13.09.2023 10:06:00, Alvaro 13.09.2023 20:30:00
