Release Manager Spice# publish error
Release Manager Spice# publish error - Сообщения
#1 Опубликовано: 22.11.2024 13:49:11
1 545 сообщений из 1 861 понравились пользователям.
I can't publish the plugin
#2 Опубликовано: 22.11.2024 16:11:36
2 328 сообщений из 4 022 понравились пользователям.
Группа: Super Administrator
Thank you for the report.
Checking...
#3 Опубликовано: 22.11.2024 16:33:13
Reproduced. Working to fix it.
#4 Опубликовано: 22.11.2024 22:15:16
Issue is troubleshot.
The reason is that the file of the plug-in is 35.5 MB which is the largest plugin right now. Server does not accept such amount of bytes because of security reasons.
Current maximum request limit is 30,000,000 bytes, which is approximately 28.6 MB.
I'm checking what can be done here...
#5 Опубликовано: 22.11.2024 22:21:23
Possibly the same issue with ImageEditRegion?
#6 Опубликовано: 22.11.2024 22:28:58
Yep, it is 30.2MB, while we are accepting not more than 28.6MB.
It will be fixed, but because of our development cycle (i.e. "temporary everything is broken" but for the good reason!) it may take up to a week...
I will let you know as soon as it is finally handled.
Вячеслав Мезенцев 23.11.2024 01:13:00, Davide Carpi 23.11.2024 00:38:00
#7 Опубликовано: 22.11.2024 22:29:26
Let's pack it in the topic with the plugin I attached an archive, which takes up only ~11 MBytes:
https://en.smath.com/forum/yaf_postsm86157_SpiceSharp.aspx#post86157
#8 Опубликовано: 10.01.2025 23:31:39
Hello.
There were many changes done to the plugins related infrastructure and I think most issues must be fixed now, including corrected GUIDs detection and large plugins packages support (up to 50MB ).
We have one more known issue: SMath Studio can't install plugin package if such package contains folders. This requires new version of the program, so it will be fixed in the next release.
Please try to build and upload plug-ins and let me know if any issues remains. I will handle them.
I also want to inform that we are preparing articles which will describe a new way how we recommend developing plugins, but those of you who interested in what is changed may already check this updated plugin: https://smath.com/svn/public/plugins/CheckBoxRegion - main changes are:
I will inform separately when articles will be ready.
Best regards, Andrey Ivashov.
Davide Carpi 11.01.2025 00:50:00, Вячеслав Мезенцев 11.01.2025 00:06:00
#9 Опубликовано: 11.01.2025 00:29:51
There is no log, the reason is unknown.
Andrey Ivashov 11.01.2025 00:43:00
#10 Опубликовано: 11.01.2025 00:50:50
Thank you!
If you click on the Download full log link at the bottom you'll see the following error:
"error NETSDK1050: The version of Microsoft.NET.Sdk used by this project is insufficient to support references to libraries targeting .NET Standard 1.5 or higher. Please install version 2.0 or higher of the .NET Core SDK."
Will try to install latest .Net SDK.
#11 Опубликовано: 11.01.2025 01:12:39
As I wrote earlier, this log has not been displayed for me for many years. When I try to download it, I get an error: File not found.
#12 Опубликовано: 11.01.2025 01:20:11
Sorry, forgot about it.
Building a plugin fixed, but as I see an output package contains folders like cs, de, es, fr, it etc... - this will break plugin installation. This is known issue but requires new SMath Studio build.
The best solution for now is to exclude these folders from output (they must be a part of third-party Nuget I think).
#13 Опубликовано: 11.01.2025 01:35:35
I'm not sure I can control this. These resources appear automatically. I don't remember which settings are responsible for this, but they are still not available to me. I can insert dependent packages in the sources instead of packages, but it's too complicated.
#14 Опубликовано: 11.01.2025 01:51:56
Ok. I'll check this a bit later today.
#15 Опубликовано: 11.01.2025 04:18:33
Done.
Spice# plugin can be built, uploaded and installed now.
To make things easier I've converted project to a new style and hope you like it.
Please try.
Вячеслав Мезенцев 11.01.2025 06:12:00, Davide Carpi 11.01.2025 19:57:00
#16 Опубликовано: 11.01.2025 16:45:16
Done.
Please try.
Yes, now everything works and I can expand the functionality of the plugin. Thank you.
The plugin is now available in the gallery.
francesco rapuano 12.01.2025 00:30:00
