Levi-Civita Symbol via Programming functions
Levi-Civita Symbol via Programming functions - Attempting to get first of 3 IF statements to work. - Сообщения
#1 Опубликовано: 28.11.2021 18:31:36
John Heidenreich
John Heidenreich
5 сообщений из 67 понравились пользователям.
I have a symbol that nearly works for all cases. At the moment I am not sure how to get the first IF statement to work.
Levi-Civita Symbol_try.sm (95,04 КиБ) скачан 1196 раз(а).
Thank you for your help in anticipation
Kind Regards,
John
#2 Опубликовано: 28.11.2021 20:16:51
Hi. The "E" in the first if isn't the same "E" than the others. You can see that looking that the bakground isn't gray, like in all others.
Oscar Campo 01.12.2021 23:54:00
#3 Опубликовано: 29.11.2021 00:04:25
John Heidenreich
John Heidenreich
That fixed it Alvaro! ...
#4 Опубликовано: 30.11.2021 12:12:24
Johannes Piel
Johannes Piel
2 сообщений из 20 понравились пользователям.
Hi John,
I did the same thing a few days ago, typing in a few less letters if you need it....
#5 Опубликовано: 30.11.2021 18:33:30
John Heidenreich
John Heidenreich
Hi John,
Your solution is more efficient than mine Jopi, yes please post your code,
thank you,
Kind Regards, John
#6 Опубликовано: 01.12.2021 07:17:49
Johannes Piel
Johannes Piel
Levi-civita.sm (8,47 КиБ) скачан 1178 раз(а).
Does anyone know how to summarize the result into a single vector?
#7 Опубликовано: 01.12.2021 15:22:31
I don't understand much in there.
As it looks your are solving Cross Product ... is it ?
Levi-civita [Not Sure].sm (12,48 КиБ) скачан 965 раз(а).
#8 Опубликовано: 02.12.2021 05:48:51
John Heidenreich
John Heidenreich
Here is the cross product Jean and also Jopi, so you are pretty close to the money.
and here is a bit more again, this time the determinant:
Here is the wedge product i am particularly interested in, see the similarity to axb?
#9 Опубликовано: 02.12.2021 10:06:11
Thanks John ...more in there from lot more convivial Smath
Shitting snow today, not to scare the bear ... Jean.
Maths vminor [cofactors].sm (40,18 КиБ) скачан 997 раз(а).
