modifying tables
modifying tables - Сообщения
#21 Опубликовано: 15.05.2019 11:51:53
Can you make a table in one SMath file, and have a calculation in another SMath file refer to the table in a calculation?
SS 6179 does not save Table in file.
Differently, a matrix data result does save and is lot more technical.
#22 Опубликовано: 15.05.2019 12:25:46
The Cross
The Cross
0 сообщений из 73 понравились пользователям.
How do I reference a matrix in another file?
#23 Опубликовано: 15.05.2019 12:48:51
you can check the features of the "include" plugin
#24 Опубликовано: 15.05.2019 20:44:12
PipeData is spooled to file from where it is created,
then recovered from wherever.
It should create SmathFile in your C:\ root directory.
If not => create it
Inst_Colebrook Pipe Data_Recover.sm (4,92 КиБ) скачан 1259 раз(а).
Inst_Colebrook Pipe Data.sm (59,42 КиБ) скачан 1219 раз(а).
#25 Опубликовано: 17.05.2019 15:09:56
The Cross
The Cross
Why is SMath not recognizing the Matrix callout?table1.sm (13,72 КиБ) скачан 1225 раз(а).
#26 Опубликовано: 17.05.2019 19:53:18
Table is a local decorative gadget, thus: not a matrix as such.
Disambiguate: Smath spools to file a Matrix but not a Table.
#27 Опубликовано: 09.01.2021 16:19:40
Ruben Sidranski
Ruben Sidranski
@Britt1,
Did you get this to work? On my list of things to torture myself with. I have a spreadsheet for this, but like keeping everything, when reasonably possible, on one platform. Moving hard to QC spreadsheets to SMath is interesting to say the least . This has been on the back-burner as it's easy to check. I actually think this will be more complicated in SMath than it's worth, thus asking if you got something to look at
#28 Опубликовано: 09.01.2021 16:56:43
@Britt1,
Maybe I understood completely wrong what you are trying to do.
But I have just deleted FU and rewrote it.
The operand was # in your example, what it means?
        <input>
          <e type="operand">FU</e>
          <e type="operand">#</e>
          <e type="operator" args="2">:</e>
        </input>
