List calculation
List calculation - Сообщения
#1 Опубликовано: 16.11.2017 13:14:55
pierre
pierre
2 сообщений из 17 понравились пользователям.
Could you tell me if their is any way to loop through a list the Way mathcad does with the I:=0..n, as a "global" methode (not inside a formula).
Below a screenshot of the case
Image explicative
Thank you for your help
#2 Опубликовано: 16.11.2017 14:03:03
No limit, even from more savant list.
ODE rkf Integrate [rkf4 2 parameters Algo].sm (120,69 КиБ) скачан 1081 раз(а).
#3 Опубликовано: 16.11.2017 14:15:17
#4 Опубликовано: 16.11.2017 14:18:27
#5 Опубликовано: 16.11.2017 14:42:21
pierre
pierre
Thanks for your reply.
I think i need to be more specific with my question.
I will make an exemple extracted from the internet (page 16)
link to the PDF
As you can see the loop is done for the whole spreadsheet, and it makes calculation notes a lot clearer.
#6 Опубликовано: 16.11.2017 15:01:37
Here you have:
The arrow over the math is the function vectorize(), and that's what you need to apply the elements of the ranges avoiding loops (that is the other way to accomplish the task)
Arie 16.11.2017 17:11:00
#7 Опубликовано: 16.11.2017 15:14:25
pierre
pierre
Thanks a lot for the explanation!
You made my day!
#8 Опубликовано: 16.11.2017 18:52:33
You made my day!
Visit "Calculation in Table"
Read more in the 12 Smath work sheets attached.
