Beta: SMath Studio 0.99.7792 (02 May 2021)
Beta: SMath Studio 0.99.7792 (02 May 2021) - Сообщения
#1 Опубликовано: 02.05.2021 10:46:08
Группа: Super Administrator
Изменения, входящие в версию 0.99.7792
Улучшения
  • Multiple improvements performed in Search functionality (better support in MathRegion; critical issues fixed; better support for search in Descriptions and Area/Separator; automatic scrolling in Document mode);
  • Cursor movement corrected while the mouse pointer is between the pages in Worksheet mode.
Исправления
  • Scrolling to cursor improved in Worksheet mode;
  • Several text encoding related issues in MathRegion fixed;
  • Worksheet/Document autoscrolling enabled during work with selection inside a Region;
  • Minor improvements performed for scrolling;
  • Switching to Header/Footer by doubleclick fixed for the Worksheets contains Separator Region and background set;
  • Text encoding related issue fixed in Plot Region.
Разное
  • Interface translations updated;
  • Refactoring.
Скачать
SMathStudioDesktop.0_99_7792.Mono.tar.gz (1,45 МиБ) скачан 2634 раз(а).
SMathStudioDesktop.0_99_7792.Setup.msi (2,33 МиБ) скачан 5586 раз(а).
sergio 02.05.2021 12:22:00, NDTM Amarasekera 02.05.2021 13:57:00, Serg 07.05.2021 11:12:00
#2 Опубликовано: 02.05.2021 13:18:24
João Felipe Seráfico Melo
7 сообщений из 62 понравились пользователям.
Hi, Andrey!
I'm facing problems for selecting and moving objects with this update.
#3 Опубликовано: 02.05.2021 13:55:01
NDTM Amarasekera
NDTM Amarasekera
Hi Andrey!
Problems with Formatted Label.
Apparently, it occurs when both text and background color is specified with "light ..." as shown.
Andrey Ivashov 02.05.2021 14:28:00
#4 Опубликовано: 02.05.2021 14:10:11
601 сообщений из 1 382 понравились пользователям.
Hi, Andrey!
Me too, there is a performance drop with moving or scrolling regions.
#5 Опубликовано: 02.05.2021 14:24:08
Hi, Andrey!
How can I reproduce it?
#6 Опубликовано: 02.05.2021 14:28:52
Hi Andrey!
To overcome this issue you need to remove spaces from color name (" "). I will fix this.
Thank you!
Davide Carpi 02.05.2021 14:42:00
#7 Опубликовано: 02.05.2021 14:44:56
Hi Andrey!
Thank you!
In the meantime I've added a workaround in the plugin.
#8 Опубликовано: 02.05.2021 15:01:28
Cleaning "~/.config/SMath" directory and reinstalling all plugins solved the performance issue.
Possibly would be resulted same with cleaning the "Roaming/SMath" directory under Windows.
Andrey Ivashov 02.05.2021 18:14:00, NDTM Amarasekera 02.05.2021 23:49:00
#9 Опубликовано: 02.05.2021 18:11:30
Hi Andrey!
Thank you!
This workaround will not work.
You need to change line
SMath.Drawing.Graphics.GetColorByName(color.Replace(" ","");
with
SMath.Drawing.Graphics.GetColorByName(TermsConverter.DecodeText(color));
This is because variable color contains value from Term where text is always encoded. While GetColorByName does not except encoded values.
In case you want to see an example: I did the same correction in the Plot Region plug-in in my latest commit in main repo.
#10 Опубликовано: 03.05.2021 00:19:42
NDTM Amarasekera
NDTM Amarasekera
Originally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
I too had this problem.
Even after a clean re-installation, the problem still exists.
#11 Опубликовано: 04.05.2021 07:32:14
Please describe in details what are you experiencing.
#12 Опубликовано: 04.05.2021 10:11:35
Sorry about the late reply.
When I open a selection box by holding the left click, it gets stucked, so I can't select objects and move them around.
I can select objects by clicking but can't drag them.
I'm testing right now and it happens only in worsheets created in previous versions.
#13 Опубликовано: 04.05.2021 13:46:26
churichuro
churichuro
29 сообщений из 79 понравились пользователям.
trouble moving
Andrey Ivashov 06.05.2021 18:01:00
#14 Опубликовано: 04.05.2021 22:47:48
NDTM Amarasekera
NDTM Amarasekera
Problem is as shown in post #13.
It occurs for files created in latest SS also.
Sorry for the delay.
#15 Опубликовано: 05.05.2021 12:30:37
NDTM Amarasekera
NDTM Amarasekera
Did another clean-reinstallation.
Now the problem is solved only for new files saved in 99.7792.
But not for previous versions.
Thank you.
#16 Опубликовано: 05.05.2021 13:08:40
Do you mean for documents created in previous versions ?
As far back to previous versions ?
As well I noticed that last version affects "0.98.6179.21440"
Roots (range) options => Can't be set anymore ± 2.5
... Takes integers only or set it back to integer.
That happened from downloading some Forum latest version
even if denied updating like usual !
Take care ... Jean
#17 Опубликовано: 05.05.2021 14:24:38
NDTM Amarasekera
NDTM Amarasekera
Yes. The last one before 99.7792.
Previous versions also. Can't remember the version number but the dates are given below.
29/05/2014
19/05/2016
27/08/2016
21/06/2018
23/09/2.18
26/06/2019
23/01/2020
Thanks.
Take care.
#18 Опубликовано: 06.05.2021 05:25:46
Martin_B
Martin_B
22 сообщений из 84 понравились пользователям.
Can't remember the version number ...
If you open the SMath file with a text editor, the second line shows the version:
e. g.
#19 Опубликовано: 06.05.2021 08:54:51
NDTM Amarasekera
NDTM Amarasekera
e. g.
Thank you.
#20 Опубликовано: 06.05.2021 09:32:04
if you can run the worksheet, just use appVersion(-digits), the negative values are for the worksheet version while the positive are for the executable.
