Vector element operations
Vector element operations - Сообщения
#1 Опубликовано: 06.06.2014 19:33:19
Cyborgtable
Cyborgtable
I've just recently discovered this software and have probably is a simple question but I can't find the answer to it.
I'm trying to square each element in a vector and can't find a way to do it.
#2 Опубликовано: 07.06.2014 02:42:55
Look at this or this or this posts. To make long story short, in SMath you should use loops for that, or to use Maxima plugin, or to use something like this.
[MATH=eng]v:mat(4,5,1,2,3,4,6,1)[/MATH]
[MATH=eng]sys2mat(mat2sys(v)^2)=mat(16,25,1,4,9,16,6,1)[/MATH]
This is many time mentioned problem from beginners
#3 Опубликовано: 10.05.2025 15:36:17
RegRetired
RegRetired
8 сообщений из 144 понравились пользователям.
Your hotlinks do not work. Please provide correct links.
Thanks,
Reg
Reg CurryLoveland, CO
#4 Опубликовано: 11.05.2025 10:44:58
