Force Units of Results
Force Units of Results - Units Question - Сообщения
#1 Опубликовано: 30.06.2014 01:45:03
Durst
Durst
Hi All
Just start with smath.
I use N mm and want result in MPa, however only get answer in Pa.
How can I force the results to be in the units I want, not in base units?
Thanks
#2 Опубликовано: 30.06.2014 03:09:35
Welcome here Durst ,
Just type the desired unit in the rightmost placeholder
You can found more info about units in the wiki: Units.
Davide
