1 страниц (4 вхождений)
Hiding Disable evaluation mark - Сообщения
Just wondered if there was anyway of removing the disable evaluation "black" mark on the top right of an expression, just for visual reasons when I write reports?
Thanks
Thanks
Use boolean equal to (CTRL+=) -- instead of assignment operator and then disabling the evaluation.
Thanks Radovan, but the same thing still happens with a boolean equal to, nevermind, thanks anyway for your suggestion
I understood you do not wanted the black box, like in this picture.
When using boolean equal to - then nothing has been calculated - can be used just for the presentation of math expressions
