Programming -> Insert a "row" in a line
Programming -> Insert a "row" in a line - Programming with lines - Сообщения
#1 Опубликовано: 29.05.2014 14:22:45
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
How do you insert a row inside a line when programing?
I know you can expand the line by dragging the box in the lower right corner but say you want to insert a row between rows which already contain information.
Thanks!
#2 Опубликовано: 29.05.2014 16:50:57
Simply press the argument separator ("," or ";", depends on your settings) at the end of the previous line.
Best regards,
Davide
Igor K 20.04.2022 01:50:00
#3 Опубликовано: 30.05.2014 13:27:26
Ryan Freund
Ryan Freund
Excellent. Thank you!
