Function intersection
Function intersection - Сообщения
#1 Опубликовано: 18.02.2017 04:03:25
mdominiak
mdominiak
0 сообщений из 23 понравились пользователям.
Hi there,
is it possible to get exact point of functions intersection in Smath somehow? I have simply linear and constant function.
BR,
Marcin
#2 Опубликовано: 18.02.2017 06:00:22
There are more opportunities: without the use of plugins, for example, you can use the function or the method of inversion of the matrix.
[albumimg]1451[/albumimg]
mdominiak 18.02.2017 06:44:00
#3 Опубликовано: 18.02.2017 06:45:09
mdominiak
mdominiak
Thanks!
What with quadratic or higher function?
BR
#4 Опубликовано: 18.02.2017 07:18:48
The method 2, of course, no; the method 1 yes, but get only one solution.
You can also use the internal function, "solve", or the plugins.
Search on the forum the plugins "nonlinearsolvers" and "maxima". Allow to extend the solution of nonlinear equations (reading the discussions can also highlight some limitations highlighted by users).
#5 Опубликовано: 18.02.2017 12:48:24
Read the first example carefully. 'solve' is inaccurate on long range
but the initial is good enough to reduce the brackets. Wise to check
with accurate 'Dichotomy'.
Forum Solve.sm (15,71 КиБ) скачан 1461 раз(а).
#6 Опубликовано: 18.02.2017 19:51:12
"roots" is a great solving companion:
solve explicit & solve general intersection.
Solve roots.sm (12,08 КиБ) скачан 1431 раз(а).
#7 Опубликовано: 20.02.2017 03:42:21
mdominiak
mdominiak
Thanks for help.
