1 страниц (3 вхождений)
Need Help - error in a SMath program - Сообщения
Hi everybody,
I am new in SMath. I'm comming from Mathcad, wih a moderate experience.
I appreciate very much this tool. It could be very useful for engineers.
I constructed in SMath a small program. I have this message that I do not understand and especially I don't now how to solve. The message is: "Result is above max. allowed positive number". I fact I constated that the result is "0.6395". When I introduce this in a neuw variable name I obtain the above message.
If necessarly, I coud offer the whole program for a expertize, by mail way.
Thanks a lot for any help,
Ioan
Ioan
Hell Ioan,
This message is often connected to the Optimization in SMath. Right click on the expression and choose from the Optimization context menu (Numeric, Symbolic, None). This might help in the case you did not divide large numbers with a rather small ones. Anyway, you can put your file on some file hosting system (dropbox, sugarsync etc.) and make a link to it here on the Forum.
WroteHell Ioan,
Thanks a lot Radovan. Really it was a optimization matter. I selected no optimization an it works.
Thanks again,
Ioan
