Solving a trigonometric equation
Solving a trigonometric equation - wrong results? - Сообщения
#1 Опубликовано: 13.03.2020 17:15:53
coeur_de_lion
coeur_de_lion
0 сообщений из 18 понравились пользователям.
Dear all,
I try to solve a simple trigonometric equation with "solve", but I don't find results in some situation and I don't understand why.
Any help is appreciated.
Thank to all
#2 Опубликовано: 13.03.2020 19:00:50
Three things here:
1. All maths fncts are Padé rational fraction.
on small range of the argument, then processed for extending.
21 floating 18 considered trues conserved 15 [standard tables].
2. '0' is undefined generally.
3. 5*π doctored
solve bloc is not fool proof all/any applications
SINE.sm (11,36 КиБ) скачан 1231 раз(а).
coeur_de_lion 17.03.2020 02:22:00
#3 Опубликовано: 14.03.2020 08:27:49
... sanity check from Casio on line calculator.
#4 Опубликовано: 17.03.2020 02:31:41
coeur_de_lion
coeur_de_lion
Dear Jean,
thank you for the answers.
To be sure if I understand right: the mistakes are from the approximation of the functions.
I apoligize, but I don't understand your "sanity check". Could you explain a little bit?
Thank you
#5 Опубликовано: 17.03.2020 09:45:18
Dear Jean,
Thank you
Often, in advanced works, we have to check [sanity check]
results. Casio [Keisan] on line calculator(sss..] is Bible.
As the matter example was Bessel: here is the document.
Link to Bessel-Keisan in turquoise.
Cheers ... Jean.
Bessel JY.sm (85,01 КиБ) скачан 1202 раз(а).
