Insert columns / rows to an existent matrix
Insert columns / rows to an existent matrix - Modify an existing matrix - Сообщения
#1 Опубликовано: 19.09.2020 12:01:39
Paul Caicedo
Paul Caicedo
Hi all,
Is it possible to add rows / columns to an existing matrix? I couldn't find that and just created another matrix with the mxn needed.
Thanks,
Paul
#2 Опубликовано: 19.09.2020 12:59:06
Select the entire matrix with the cursor and drag the rectangle that appears.
#3 Опубликовано: 19.09.2020 15:17:02
You can add row(s), col(s) that you have defined/valued or will define/value
from elsewhere in the project ... all that to an existing matrix.
Utilities Matrix Treasury_1.sm (412 КиБ) скачан 1206 раз(а).
#4 Опубликовано: 19.09.2020 16:30:00
Paul Caicedo
Paul Caicedo
Thanks to both of you for the valuable answers
#5 Опубликовано: 20.09.2020 09:31:15
Applied to Fourier Convolution, from isolated data set.
Cheers ... Jean [1983, I was up there Syncrude Fort McMurray]
Paul 33.sm (57,94 КиБ) скачан 1144 раз(а).
