Modify a .exe files
Modify a .exe files - Сообщения
#1 Опубликовано: 18.04.2021 06:55:40
Salvatore
Salvatore
Hi everybody,
I tried to search for the same problem but I have found nothing.
I created a new_file.exe with smath.
Could I open and modify the related new_file.sm if I, unfortunately, forgot to save it?
#2 Опубликовано: 19.04.2021 13:51:28
Hi. If you make the exe file with the full version, I guess that you have a button for do that. With the free version you can save as "SMath Viewer file type" xml with Control-S.
#3 Опубликовано: 20.04.2021 09:22:33
Salvatore
Salvatore
First of all, thank you!
But after I have saved it in an XML file how I can convert it into a .sm file?
#4 Опубликовано: 20.04.2021 17:45:38
Hi. I guess you can't. It's a format for the viewer, not for the program.
But actually I don't know about the SMath internals, only know a few things about the program when they are reflected back to the user, such as the use of Control-S or the xml formats, just because they are open source files.
Please, check this information at this post:
"Taking everything into account I decided to try to change something... and to introduce subscriptions. Preliminary, there are 3 options to be available:
1) Simple: SMath Studio in the Cloud in guest mode, SMath Studio Desktop will work as it does today;
2) Existing account at smath.com: personalized SMath Studio in the Cloud, auto fill properties for new worksheets from the user Profile, synchronization of the settings, etc.;
3) Paid plan (f.e. annual, based on the number of users in Organization): unlimited disk space on SMath Studio in the Cloud, full featured SMath Viewer Pro, deep integration with SMath Studio in the Cloud; additional documents backup options; support by e-mail/Skype."
#5 Опубликовано: 27.04.2021 12:45:09
26 сообщений из 155 понравились пользователям.
The whole point of .exe files is to protect the logic of the calculation sheet. There is a good chance that converting back to .sm is probably no easy task.
#6 Опубликовано: 13.05.2021 04:17:14
Mixeu
Mixeu
0 сообщений из 7 понравились пользователям.
Преобразовать обратно не сможешь, а вот если нажать печать, то должен распечататься лист файла .sm. Ну а потом ручками. Я только такой вариант нашел.
