HIRES Chokes Smath Rkadapt
HIRES Chokes Smath Rkadapt - HIRES Chokes Smath Rkadapt - Сообщения
#1 Опубликовано: 09.10.2016 02:37:18
The max span is 0..10 Else attempt gives either two types of error.
The setup is correct but the result is a bit short of production.
Designers: that is just a report for your bed time thinking.
Cheers, Jean
ODE Rkadapt HIRES.sm (562,62 КиБ) скачан 1402 раз(а).
#2 Опубликовано: 09.10.2016 04:04:00
Hello Jean,
Why don't you use stiff solvers, for example from DotNumerics plugin. They will cope with this equations well (dn_AdamsMoulton, dn_ExplicitRK45, dn_GearsBDF..).
P.S. By the way, uni made many ode solvers in few plugins, and I think SMath is very good regarding ODE solvers
#3 Опубликовано: 09.10.2016 10:45:08
Thanks Radovan,
Here is well done, Jean
ODE HIRES.sm (41,06 КиБ) скачан 1367 раз(а).
