Page Setup Defaults
Page Setup Defaults - Is it possible to change and save the Page Setup defaults - Сообщения
#1 Опубликовано: 13.07.2018 13:41:29
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
Is it possible to change and save the Page Setup defaults?
Thanks!
#2 Опубликовано: 14.07.2018 12:53:34
Thanks!
Try this
1. Open PC
2. Open Smath.
3. Page setup as you wish
3. Save page as "Template"
4. Close Smath
5. Open Smath, Template
#3 Опубликовано: 14.07.2018 16:03:11
Ryan Freund
Ryan Freund
Jean - Thanks you are correct, that does work for new sheets. I will do this going forward.
It would be nice to set this as default as I will still need to modify old sheets, but this is a good work around for now.
Thanks again.
#4 Опубликовано: 14.07.2018 21:00:11
Up to version 6179, open a work sheet created "Portrait"
Change setup for "Landscape", save ... it re-opens "Landscape"
It also saves new borders/margins ... Try it.
