Paste Problem in Ubuntu
Paste Problem in Ubuntu - Сообщения
#1 Опубликовано: 14.11.2009 12:32:28
Waluyo Adi Siswanto
Waluyo Adi Siswanto
1 сообщений из 55 понравились пользователям.
Dear Developers
In Ubuntu 8.04 and 9.04 "paste" cannot be used, just doesn't work.
I tried all possible ways to paste an equation after "cut" or "copy" but all did not show any result.
I tried, Ctrl-V, press the paste button, also from the menu Edit > Paste.
Is it a bug or is there any way to copy an equation and paste somewhere to modify?
Regards, waluyo
#2 Опубликовано: 19.11.2009 01:32:51
Группа: Super Administrator
I know about this bug (someone already mentioned about it). As I understand it is happens on some OS' under Mono. I've tried to fix this but had no success. Will try again soon. Thanks for the report!
#3 Опубликовано: 23.11.2009 12:54:29
Waluyo Adi Siswanto
Waluyo Adi Siswanto
For the time being in Ubuntu, copying a formula and paste it to different place is possible, by selecting "inside" the formula region and paste (or Ctrl-V) it somewhere. Of course I can copy maximum 1 region only. But at least this trick helps me, I do not need to retype again similar equation within SMath,
Regards, Waluyo
