Problem with variables
Problem with variables - Сообщения
#1 Опубликовано: 03.11.2021 23:48:49
Lelar
Lelar
0 сообщений из 7 понравились пользователям.
Smath don't save me the variables and I can't evaluated the expression. What I can do it?
#2 Опубликовано: 04.11.2021 05:54:19
1) post a minimum example that reproduces the problem
2) Try to download one of the numerous examples on the forum (they are almost all well-functioning) to verify that there are no installation problems or you do not use the commands correctly.
#3 Опубликовано: 04.11.2021 09:28:46
601 сообщений из 1 382 понравились пользователям.
Auto Calculation is not enabled probably.
