Condense or Collapse cases()
Condense or Collapse cases() - How to delete rows of cases - Сообщения
#1 Опубликовано: 09.04.2015 10:55:34
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
Is it possible to delete rows of cases() ? Say you add too many lines to cases then want to delete them. Is this possible?
Thanks!
#2 Опубликовано: 09.04.2015 11:12:58
Not directly.... I've asked Andrey before introducing that function and he said that the resize control used in matrices and sytems is hardcoded.
You have to copy the function and edit the code in a text editor (remove a couple of placeholders).
#3 Опубликовано: 10.04.2015 10:08:56
Ryan Freund
Ryan Freund
Thanks Davide
