Login Cloud
Login Cloud - Сообщения
#1 Опубликовано: 29.04.2020 06:31:23
haweHofmann
haweHofmann
3 сообщений из 32 понравились пользователям.
Hallo zusammen,
is it possible that a multiple login to cloud (https://de.smath.com/login.aspx) is blocked?
cannot log in from Ipad ( or other browser on same device)
Wrong login/e-mail or password.
Check you credentials and try again.
pw is definitely not wrong.
Very annoying, because the login remains even if the PC is logged off and who thinks about logging out because he might want to log in with another device.
It seems that I can only login by restore access - once logged out I can not get a login again
Is there a difference cloud/forum account?
#2 Опубликовано: 06.05.2020 16:46:45
2 335 сообщений из 4 031 понравились пользователям.
Группа: Super Administrator
Hello.
Yes there are two different credentials: one for the forum and another for SMath Studio Cloud.
This is because I'm using third-party forum engine and it is pretty complex thing to switch forum so it will use another authentication engine.
Hope it will help you.
#3 Опубликовано: 06.05.2020 17:22:28
haweHofmann
haweHofmann
Hello.
It explains at least why I have access to the forum and problems login to the cloud.
could it be possible that exists 2 cloud accounts with my email address?
To login cloud I have to restore access every time I want to login.
