Hydro Power Estimate
Hydro Power Estimate - A first estimate of hydro power potential from stream flow data - Сообщения
#1 Опубликовано: 20.10.2015 11:10:01
NDTM Amarasekera
NDTM Amarasekera
Attached is a Smath file showing how a first estimate is made of the hydro power potential from stream flow data.
This is based on the "Example 6.11 - E.M. Wilson - Engineering Hydrology - Fourth Edition - Solutions to Problems" published as a solution manual to the text book by the same author.
Hydro Power Estimation-Wilson Ex 6.11.sm (66,87 КиБ) скачан 1553 раз(а).
Davide Carpi 20.10.2015 14:07:00, overlord 08.04.2016 08:16:00
#2 Опубликовано: 08.04.2016 08:17:49
integrals aren't calculated in this example. Culprit is maxima plugin.
