Help Snippet
Help Snippet - Tables of SMath operators and their keyboard input - Сообщения
#1 Опубликовано: 08.08.2014 17:45:22
1 353 сообщений из 2 264 понравились пользователям.
The snippet contains tables of operators and functions with special formatting and their corresponding keyboard input.
This might be of help until these functions all made it into the side panel (feature request SS-202)
There are some problems with the formatting of expressions in the tables, see SS-201
Usage:
- type "help" and press TAB - the tables are inserted in an area region
- expand the area region and inspect the tables
- if you are done, just collapse the region and delete it.
Davide Carpi 08.08.2014 19:58:00, Radovan Omorjan 09.08.2014 01:18:00, ioan92 09.08.2014 03:49:00
#2 Опубликовано: 09.08.2014 01:37:10
Thank you Martin for this one
By the way, I do not know if this was reported as a bug but if I try to move right with the bottom slider - unhandled exception occur.
When expand the area, put the cursor below it (red cross), and try to move bottom slider.
See this video
Could someone try to reproduce this. Unfortunately, I have the impression that using area regions looks like "walking on eggshells".
#3 Опубликовано: 09.08.2014 02:46:27
2 326 сообщений из 4 013 понравились пользователям.
Группа: Super Administrator
Radovan,
This is the last Area related known issue (already fixed) and it is described here: http://smath.info/bts/Issues/IssueDetail.aspx?id=194
#4 Опубликовано: 09.08.2014 03:17:05
Radovan,
Sorry Andrey. I forgot to uncheck the "Exclude closed issues" in searching the bugs report and did not find it.
Anyway, thank you for fixing it
